I tried to Edit the Whse. Phys. Invt. Journal but it says that the locations for the warehouse employee is not enabled for WMS !
How do I enable the location for warehouse employee for WMS ?
Cheers
Dave K
Cheers
Dave K
Did you setup Warehouse Employee’s setup properly?
You need to add User with combination of WMS location in Warehouse Employee Setup.
How do I make a location into a WMS location ?
You need to Set Directed Put-away and Pick field in Location Card to Yes.
This field Specifies if you require the location to use advanced warehouse functionality, such as calculated bin suggestion.
