how do i color a column in grid based on a condition
how do i color a column in grid based on a condition?my requirement is like if the condition is not met,that particular column is highlighted red.
In AX 2012, XYZ/Project management and accounting/Common/Timesheets/All timesheets
While editing a timesheet ,we have no. of hours per day a worker has to work.If its less than min no. of hours,that particular column should get highlighted red.
I have tried display option method in form datasource “TSTimesheetlineweek”,but no success.
:slight_smile:
what code have you written to highlight the column ??
Can you share it ??
public void displayOption(Common _record, FormRowDisplayOption _options)
TSTimesheetLineWeek _TSTimesheetLineWeek = _record;
Real minhours = 8.00;
if (TSTimesheetLineWeek.Hours[1] < minhours )
_options.backColor(8421631);
_options.affectedElementsByControl(TSTimesheetLineWeek.Hours[1].id());
//(here i am getting an error,“Variable TSTimesheetLineWeek_Hours has not been declared.” Even after making AutoDeclaration “Yes”)//
super(_record, _options);
Same I tried in active method also,
public int active()
int ret;
real minhours = 8.00;
int i;
TSTimesheetLineWeek_Hours[1].colorScheme(FormColorScheme::RGB);
TSTimesheetLineWeek_Hours[1].backgroundColor(Winapi::rgb2int(255,0,0));
else
TSTimesheetLineWeek_Hours[1].backgroundColor(Winapi::rgb2int(255,255,255));
ret = super();
return ret;
Again same error!! “Variable TSTimesheetLineWeek_Hours has not been declared.”
Hi Shyam,
http://chaituax.wordpress.com/2013/03/07/changing-color-of-records-based-on-flag-in-ax/
this might help you…
My problem is why the form design control name “TSTimesheetLineWeek_Hours[1]” is not getting declared,even after making Auto Declaration “Yes”.
Otherwise the code is correct in active method,its working fine for other form design control.
That’s a good question that I am interested in since I am recently also new to a grid UI control. The suggestions here are quite helpful, it could be better if I can see more codes demonstrating the method. Is there something like the grid color column? However, this thread already helped me a lot with much insights offered. Cheers.
