How divide database several disks?
Hi, I need to divide the database if several disks, but I don’t know how do it. The backup was created (.fbk) and two databases was created at diferent disks, but I don’t know how I must continue. Please, somebody knows how do it? Are there any documentation about this issue anywhere? Thanks very much!!! P.D. ¿Alguien que hable castellano puede ayudarme?, como veis el inglés aún no se me da del todo bien…¡¡¡¡GRACIAS!!!
Are you running C/Side or SQL database?
A good question!!, The server is running Attain 3.10, I supose C/Side Thanks!!!
Menu = File Option = Database, Expand Select Advanced Button On new line(s) add location/name of extra database file(s). To gain maximum benefit make sure that databases on different physical disks!
Daniel, before doing this with you live system, please do one of two things, a/ contact your NSC for help, or b/ read this manuals. You really don’t want to shut the compan down by screwing up thhe server. the manuals are on the install cd.
oh and one thing not mentioned in the manuals… during a database expand, the version principle does not work, so if you have any type of failure whilst expanding, then you loose everything.
Thanks David, I’m testing in a “cut off server”. If the process isn’t wrong then I will to decide if we call to our dealer for help. In this moment I have a problem, while I restart the backup in database, at end of process the server say “Internal Error 1355 In module 19”, I don’t know why!!! Fortunately is a test server…UF!!! (The real test is working)
