It appears that when we make changes to an item’s description, the change is not updated in the Planning Lines of Items or Jobs. We also can’t find a “Where Used” feature that we could at least find where these items are and change them manually. Is there a way to automatically change the description.
Try to write a custom code to change item description automatically if any changes made in item description, in Item table Description field on validate trigger you can write the code.
Thank You
