I am filtering one field value on Open Form(). But I wanted to hide those filters from table filter to hide from the view of users. Please help me to complete this requirement.
Can you be more clear?
Hi Mohana,
While opening GL entries form, some entries which is posted by using a particular Journal Batch Name(say ‘AUTOJV’) should be filtered out. I have done this by using SETFILTER(“Journal Batch Name”,’<>%1’,‘AUTOJV’); in On Open Form() trigger and it is working fine. But those filter is appearing in table filter. It should be hide from the view of some users and it should be appear for the key users to remove that filter(AUTOJV).
Jithin.
Hi Mohana,
While open GL entries form, some posted entries which is posted by using a particular Journal Batch Name (say AUTOJV). This is done by using SETFILTER(“Journal Batch Name”,’<>%1’,‘AUTOJV’); in On Open Form() and it is working fine. The filter is appearing in table filter while opening the form. It should be hide from the view of some users and it should be appear for some key users to remove the filer(AUTOJV).
Jithin.
Disable System permission 3220 - View, Table Filter for those users…
Sorry sir. I din’t understand. Where I have to set this permission.
In Roles assigned to him on Windows/Database Authenticatin
Tools–>Security–>Winwos/database Authentication–>Roles
Can you try :
FILTERGROUP(2);
filters…
FILTERGROUP(0);
I would suggest better create sepeatre batches for every user.
Add UserId field in Gen.Journal Batch Table
Change code in CU 230 Function Name LookupName
GenJnlBatch.SETFILTER(GenJnlBatch.“User ID”,’=%1’,USERID);
For Super User If you want to show all batches then you can do following
Add Show All batches in User Setup Table
recUsersetup.SETFILTER(recUsersetup.“User ID”,’=%1’,USERID);
IF recUsersetup.FIND(’-’) THEN
IF NOT recUsersetup.“Show All Batch” THEN
Hope this will help you.
Hi Anil,
This is working fine. But I couldn’t understand what is happening behind. What is the normal use of FILTERGROUP?.
Now that filter is not appearing for all the users. How can I give user wise filter?
Jithin.
Hi Mohana,
Still I couldn’t findout those roles. Kindly give some more explanations…
You should contact your senior
