How can i SELECT DISTINCT IN X++ select statment
hi guyz in sql its possible to use SELECT DISTINCT in cases where a table has duplicate value
how can i achieve this in X++ select statement
U can use ‘like’ keyword to find the duplicates.
Ex:-
select contactPerson
where contactPerson.(whereFieldId) == this.AccountNum
&& contactPerson.Name like _name;
Hi Kimmi,
Use ‘GroupBy’ in the select statement which field you want the distinct records.
Naresh Kolli
i just want to select one record distinctively out of the duplicates.
assume i have a table with customer transactions i want to select distinctively all customer that have transactions in that tables
without duplication. just the way the sql statement SELECT DISTINCT works
naresh
thanks that works perfectly!
Hi Kamini
An Naresh said you can use Group By;
while select count(recId) from rentalTable
group by rentalTable.CustAccount
info(strfmt(" Customer %1 has rented cars %2 times", rentalTable.CustAccount, rentalTable.RecId));
