How can I save createddatetime value to another table with Insert_recordset ?
Hello,
There ara 2 tables. Table1 and Table2.
The following code gives an error .
Insert_recordset Table2 (field1_utcdatetime)
Select createdDateTime From Table1;
But this code is not error;
While Select createdDateTime From Table1
Table2.clear();
Table2.field1_utcdatetime = Table1.createdDateTime;
Table2.insert();
How to save it with insert_recordset method?
Could you please tell us what error do you get?
“The Application Object Server is unavailable. Check your configuration an network connection and try again” …!!!
ttsbegin;
insert_recordset tbTarget (Date1,TFielld1)
Select createdDateTime,SField1 from tbSource Where tbSource.SField1 == “123”;
ttscommit;
Error is “The Application Object Server is unavailable. Check your configuration an network connection and try again”
But…
ttsbegin;
insert_recordset tbTarget (Date1)
Select createdDateTime from tbSource Where tbSource.SField1 == “123”;
ttscommit
Error is "TargetTable ( TargetTable ) can not be played on a data definition language command. SQL database gave an error "
