I am using NAV2013.
Actually I have excel file with data and i have to import this data to the table but by data migration, so any one can tell me about
Data migration process. That table i also just created.
Thanks in advanced[:D]
I am using NAV2013.
Look at the folllowing link
http://msdn.microsoft.com/en-us/library/hh179459(v=nav.70).aspx
You need to select the table in data migration, select the required fields & use export to excel.
Fill the excel sheet created and then import the excel sheet from data migration function itself.
Data Migration functionality is not available in NAV2013.
Its called Rapid Start Services.
Have a look at this video for basic idea…
http://mohana-dynamicsnav.blogspot.in/2013/04/how-to-import-and-post-opening-balances.html
