I have a report, in that i added a vertical line (Shape Control) for Item Description Column. The Column is changing dynamically as per the size of the text. Also I need the same to the Dredgers Column where it should dynamically change the height based on the height of the Item Description Vertical LIne. Please find the report for reference.
Thanks in advance.
