How can I call Crystal Report by send parameter ?
How can I call Crystal Report by send parameter ? When I call Crystal Report by send parameter from navision . Can I do it? if I used shell command , Thank you
There is an OCX to print reports. You’d probably have better luck automating Crystal Reports. Good luck! Django
You’ll probably prefer to develop your reports directly in Navision, using the report builder. The performance will be much better, and you have a lot of options. If you are looking for a more friendly-user solution, JetReport does also a good job.
