Hello ,
How can be Display data of two diffrent comapany in a single report .
I want to show two different company’s data from my single report means when user click report it will show two report with different comapnay’s data .
Hello ,
Hi Verma,
you can use the “changecompany”,
changecompany(‘company1’)
select Table…
changecompany(‘company2’)
select Table…
valeru.
or directly you can declare the “CrossCompany” in the select statement. have a look at the following sample code.
static void JobDemoCrossCompany(Args _args)
BankAccountTable tabBAT; // saveDataPerCompany == true.
container conCompanies = [ ‘cm1’, ‘cm2’, ‘dat’ ];
str 4 sCompanyPrevious = " "; // Maximum length is 4 characters.
int iCountCompanies = 0;
while select
crossCompany
: conCompanies
Thanks to both of you …
Now my requirement is diffrent now i want to display report according to company parameter means when dialog open user select company (it can be more then one means multiselect in company field ) it will show report according to selection of parameter means user select 2 companies it will show report in diffrent window with diffrent company data .
Again thanks in advance
