Hi everybody as all you know , dynamics ax 2009 supports hijri and um al qura calendars and date system i want to know how dynamics converts georgian date to hijri i mean is there any class in AOT that is responsible for this job? there is a class in AOT named calendarconverter but its just responsible for calendar lookup form and axapta converts georgian date to hijri in another way. its really important for me and my job to know and find this class if exist thanks for your care
Can you explain in detailed…
Hi naresh
what type of explain you want?
i think i explained everything
when you set axapta preferred calendar to hijri , it converts all dates to hijri date
im searching for a class that is responsible for converting dates in axapta ( the class that converts these dates to hijri)
Hi harish
thanks for your care and answer
but i had seen this blog before , in this post amer tries to use a new way to show hijri dates but i want to know axapta date conversion mechanism itself
Hi Maziar,
Have you looked at CalendarConverter class? In particular have a look at methods such as ‘addMonths’, ‘addYears’ etc.
Hope this helps!
Hi Harish
thanks for your care but
as you can see i wrote about this class in my first post
i should repeat that this class is just responsible for calendar lookup , NOT DATE CONVERSION SYSTEM.
even when you change calendar lookup form to another calendar like jalali , when you choose a date in that calendar , it will write hijri date in your selected field
What about winapi?
do you think that it may use windows dll’s?
like microsoft access
Hi Maziar,
If you study the class, you will notice that it is using CLR Interop classes. Again I refer to another post in Amer’s blog here - http://blog.amer-ax.com/?p=378.
