Here I have a form A. This is having three fields.startdate and Enddate and TotalWorkedhours.
Example:: startdate : 7/30/2012
EndDate : 7/31/2012
TotalWorkedhours (HH:MM): (23:52)
i have to show the total time variance between start date and enddate in TotalWorkedhours (HH:MM) field.
(Format should be in HH:MM format only)
you should have a look at dateTimeUtil class, it has a fonction that returns difference between 2 datetime values:
dateTimeUtil::GetDifference(date1,Date2)
hope it helps
regards,
Thomas
Hi kola give me u r email id , i will send u xpo file in Ax2012. its not that easy to give you answer here.
thanks
Ravi
static void Job5(Args _args)
int hh, totalTime,mm,ss;
int quotient;
int tt;
totalTime = 3599; //Total seconds
quotient = totalTime/60; // total minutes
print quotient;
hh = quotient/60; // total hours
print hh;
mm = quotient mod 60;
print mm;
ss = totalTime mod 60;
print ss;
tt = 66060;
print tt;
pause;
I was developed in class for your task, BY using this method if your enter utc startdate Time and utc enddate Time its returns u r required format, like 23:06:05. already i replied in job still if u wont get let me know your mail id , i send you class file in xpo file and documentation
Hi Ravindra,
Thank you very much for your quick reply.
axexpert@hotmail.com
This is my email id.
