Highlighting preferred customers
Good day.
I need to highlight in the form of sales orders (SalesTable) some customers who are registered in a particular group.
Below is the code I’m writing, however, was unable to put the parameter group of customers I need.
public void displayOption(Common _record, FormRowDisplayOption _options)
#define.DarkGray(80, 80, 80)
#define.LightGray(200, 200, 200)
#define.White(255, 255, 255)
CustTable CustTable;
CustTable = _record;
super(_record, _options);
if (CustTable::find(SalesTable.CustAccount).AccountNum)
_options.backColor(WinAPI::RGB2int(#DarkGray));
_options.textColor(WinAPI::RGB2int(#White));
else
if (SalesTable.CustAccount)
_options.backColor(WinAPI::RGB2int(#LightGray));
In the customer master table CustTable), I could already stand out as code below.
#define.Red (255,0,0)
CustTable localCustTable;
localCustTable = _record.data();
if (localCustTable.CustGroup == ‘CLI_PR’)
_options.backColor(WinAPI::RGB2int(#Red));
else
Can anyone help me?
Hugs.
You get _record parameter, assign it to custTable variable and never use it. Instead of that, you refer to salesTable.CustAccount. That’s likely the problem.
Hi
try this
SalesTable SalesTable;
CustTable CustTable1;
CustTable1 = _record;
if (CustTable::find(CustTable1.AccountNum))
else
But how can I get in CustTable these records defined as “preferred” and highlight them in SalesTable?
If I do not comment on SalesTable, it does not compile the method, and commenting on, the following error appears:
" The field whose ID is '0 ‘does not exist in table’ SalesTable '."
You asked: "how can I get in CustTable these records defined as “preferred”? But how do you define “preferred”?
I guess that you added the method on a SalesTable data source (but you would have to confirm that), therefore _record contains a SalesTable record and not CustTable. If it’s so, the assignment custTable = _record is wrong - you should use SalesTable salesTable = _record.
Martin’s right!
Realized the change as you recommended, I added the parameter I need, however, still did not work.
Here’s how the code looks:
SalesTable = _record;
if (CustTable::find(SalesTable.CustAccount).AccountNum && CustTable.CustGroup == ‘CLI_PR’)
else
