hi,
I Ve Dought ,How Can I Import Tables in AX5.0 Into AX 4.0
hi,
You are unable to do that because you are going for a lower version.
Vinay
Means, You want to move tables from a higher version to a lower version. Which tables you are trying to Import and why?
You can make an Export and Import - but you need to analyze the consequences of it based on the objects you are going to import.
