Hi I need to display a message or infolog when opening the ax
hi how can i do this guys?
thx in advance.[:)]
Hi Mohammed,
For this, you can put infolog in class Application, method StartupPost.
I hope, it helps
Hi Mohammed!
If you want to show your message constantly, modify the config file (xpo) in this line:
startupmsg,Text,
For example if you want to show the ‘Hello World!’ message:
startupmsg,Text,Hello World!
(Anyway check the SysStartupCmd class. It’s good for system startup processes you want to run.)
I have to mention that I work with AX 3.0.
Hi Manish
I can’t find class Application in AX4.0
Mohammed : What version of AX are you using ?
Jimmy
Hello,
In Ax 4.0, to execute code in the server tier - it has to be implemented in Application → StartupPost method
If code has to be executed in the client tier, it has to be implemented in Info → StartupPost method.
Both these classes could be found at the end of Classes node.
Hope this helps,
Ohh yes there it is - that works thanks
Jimmy
