hi,
in my table there are two fields like “RouteId” and “Esculated RouteId”.
if RouteId is A and Esculated RouteId is B if B is existed in “RouteId” then find out the EsculatedRouteId
if the Esculated RouteId is C for RouteId B then again we have to find out the C is existing in RouteId
RouteId EsculatedRouteId
A B
B C
C D
how to write code for it
Regards
jhansi
try this,
select firstonly tablebuffer
from table
order by tablebuffer desc
where tablebuffer .recid < table1.recid;
u will get the prevous record.
thanks for ur reply
the two fields are in the same table we need to find out the last record.
A B
B C
C D
we have to find and returns the last record i.e RouteId is C
here we have to write looping condition every time it will work through the loop.
Regards
jhansi
str temp,temp1;
temp=table.firstfield;
while select tablename
if(temp==table.firstfield)
temp = table.secoundfield;
temp1=table.firstfield;
info(“temp1”);
we have aggrigate functions right one of them is minof…
//to find the last record in a table
while select tablename where minof(table.recid)
info(“table.firstfield”);
static void project(Args _args)
TableName tb,ntb;
str temp;
int i;
i=1;
while select tb
temp=tb.EsculatedRouteId;
while select ntb
if(ntb.routeid==temp)
i++;
break;
if(i==1)
info(nt.routeid);
else
i=1;
