I am writing a report with part #, and unit cost off the Item table 27. I am trying to standardize on 2 decimal places.
I tried 2:2 under decimal places for the properties of the field and it didn’t do anything.
I tried the ROUND function but it now leaves no decimal amount only whole dollars.
Is there a way to use ROUND and still keep 2 decimal places?
Thanks in advance,
Greg
Can we see your rounding code?
To the nearest value (default)
Up
Down
RoundedResult := ROUND(“Your Value”, .01,’=’);
Harry,
I put it on the Source Expr. of the report field.
ROUND(“Unit Cost”,2)
Greg
Greg, this will round to even numbers only!
1.01 will round to 2
3.12 will round to 4
4.99 will round to 4 as well.
What the round function in NAV really does is:
ROUND(3.12, 0.01) will execute as follows:
x := 3.133 / 0.01; // = 313.3
x := ROUND(x) // = 313
x := x * 0.01; // = 3.13
That is the reason why NAV receives the “Precision” as second parameter rather than the number of decimals as in other programming languages.
Therefore your “precision” (= smallest amount) can be any decimal like 0.05 as used in Finland quite often.
ROUND(3.133, 0.05) will execute as follows:
x := 3.133 / 0.05; // = 62,66
x := ROUND(x) // = 63
x := x * 0.05; // = 3.15
So this function is much more flexible in NAV than it is in the most other languages.
I had to make the precision a Variable with a value of 0.01 and it works now. Thanks to both Harry and Thomas.
Here is my code:
gsUnitCost:=0;
gsRound:=0.01;
gsUnitCost:=ROUND(“Unit Cost”, gsRound,’>’);
I used gsUnitCost for the report source expression.
yes ROUND(“Unit Cost”,2) 2 isn’t the way to specify 2 decimal places - it would be .01
1 = no decimal places
.1 = 1 decimal place
.01 = 2 decimal places
.001 = 3 decimal places
Another quick question. Can you add the Currency $ to the report field? If so how is it accomplished.
Greg
It’s just visual for the report correct?
SourceExp = ‘$’+format(“Your Decimal Field”)
SourceExp = ‘$’+format(gsUnitCost)
Yes it’s just for the report.
Thanks Harry,
Greg
Harry when I use it I lose the decimal places. The $ sign works great though.
Greg
I’m not sure I know how that’s possible - are you sure your field is wide enough now that the $ has been added.
I’ve tried it here and it works fine.
So your saying the field has 2 but when you change the source exp to ‘$’+format(“your field”) it loses it’s decimals?
I just double-checked it Harry.
Some are 2 dec. places, some are 1 dec. places and a lot of them are 0 decimal places. There is no fixed decimal anymore.
Greg
‘$’+FORMAT(ROUND(“Unit Cost”, .01,’>’))
‘$’+FORMAT(gsUnitCost, 0, ‘<DECIMALS,3>’
Thanks again Harry and Thomas.
I’ll give them a shot.
Greg
This solved it. Thanks again Harry and Thomas.
‘$’+FORMAT(gsUnitCost, 0, '<DECIMALS,3>)
Greg
After making the change all the $0.00 are showing up now. Is there a way I can get them not to print? Before if there wasn’t an amount they wouldn’t show.
Greg
Do you want to skip them or Blank them - Have you tried setting
BlankNumber property to BlankZero?
Ok try this - There is a proprty called FORMAT!!
Format → $<Sign,1>
BlankZero-> YES
SourceExp - Back to it’s original Field. The format property should apply the $ for you.
Eample…('unit cost") instead of ‘$’+Format(“Unit Cost”)
