HELP!! Splitting up Company information
[:0][:0][:0] HELP!! [:0][:0][:0] Our company is currently in the process of restructring itself into two seperate companies for tax purposes. I understand that I can create a new company in Navision and carry o from there. But what I am wanting to know is, is there a way to Export information from the original company and have it go into the appropriate company or is this going to have to be a table by table thing. Also are there any tools out there that do this??? [:(] Sad part is I just found out about this today (03/26/03) and have a deadline of April 1,2003. HELP!!! Please!!!
  1. Backup the company you wanna split up. 2) Rename the remaining company to the new name 3) Restore the company again and give it the correct 4) Delete the records/information you don’t need in each company And finally save the back you just made - for JUST IN CASE…
“DING” the light just came on…TKS.
Make a company copy application based on recrefs. By the use of recrefs you can create one copy function wich apllies to all tables. You can even create the possiblity to let the use define the fields that have to be copied. So the end result will be you entering a list of table you want to copy, and pressing the copy button. btw, this is my idear, I have all the rights. I want to be able to upload this application on this site [;)]
darn, it’'s not possible to change company on a recordref. So this mean my solution will not work. Sry…
