Help needed: The Vs Code debugger (AL code) does not work; does not stop on breakpoints
I have been going through AL code instruction through learn4d365.com. I have created a codeunit app and published it to a Business Central sandbox. It works as expected.
However, when I attempt to debug the AL code in VS Code, I have encountered issues with the debugger. The debugger does not break on breakpoints. The only result I have seen in the debugger is that the CALL STACK will sometimes show “RUNNING.”
Expected behavior: VS Code should stop on breakpoints and show elements (call stack, variables) in debugger side panel. In the training video this works, so not sure what I am missing or if it is an actual bug with VS Code / AL code / Business Central.
I have posted the issue on Microsoft/AL (GitHiub) – waiting for more feedback. As well, I posted the issue on Dynamics 365 Business Central Forum and was directed here, to the Dynamics 365 Business Central/NAV User Group.
Any feedback here is appreciated.
The files listed below (launch.json, app.json, codeunit, and settings.json) show what I am working with along with a screenshot of the debugger after the subscription is called. Confidential / private data has been obscured.
launch.json
“version”: “0.2.0”,
“configurations”: [
“name”: “Microsoft cloud sandbox”,
“request”: “launch”,
“type”: “al”,
“environmentType”: “Sandbox”,
“environmentName”: “XYZ -SANDBOX”,
“startupObjectId”: 22,
“startupObjectType”: “Page”,
“breakOnError”: true,
“launchBrowser”: true,
“enableLongRunningSqlStatements”: true,
“enableSqlInformationDebugger”: true
in launch.json had also tried:
“breakOnRecordWrite”: true (no effect)
app.json
“id”: "XYZ ID”
“name”: “XYZ Name”,
“publisher”: “XYZ Publisher”,
“version”: “1.0.0.0”,
“brief”: “”,
“description”: “”,
“privacyStatement”: “”,
“EULA”: “”,
“help”: “”,
“url”: “”,
“logo”: “”,
“dependencies”: ,
“screenshots”: ,
“platform”: “17.0.0.0”,
“application”: “17.0.0.0”,
“idRanges”: [
“from”: 60000,
“to”: 60049
“contextSensitiveHelpUrl”: "XYZ URL”
“showMyCode”: true,
“runtime”: “6.0”
codeunit
[EventSubscriber(ObjectType::Table, Database::Customer, ‘OnAfterValidateEvent’, ‘Payment Method Code’, true, true)]
local procedure XYZ_Customer_MethodPaymentCode_OnAfterValidate(var Rec: Record Customer)
var
SalesHeader: Record “Sales Header”;
begin
SalesHeader.SetRange(“Sell-to Customer No.”, Rec.“No.”); // set breakpoint set here, and every other line of code without effect
Message(‘Change made to the Customer Card Payment Method Code’);
Count := 0;
if SalesHeader.FIND(’-’) then
repeat
Count := Count + 1;
until SalesHeader.NEXT = 0;
MESSAGE(Text000 + ‘%1’, Count);
Count := 0;
if SalesHeader.FindSet(true, false) then
repeat
Count := Count + 1;
MESSAGE(Text001 + Text002 + ‘%1’, Count);
SalesHeader.Validate(“Payment Method Code”, Rec.“Payment Method Code”);
SalesHeader.Modify(true);
until SalesHeader.Next() = 0;
end;
var
Count: Integer;
Text000: Label 'SalesHeader.FIND Count: ';
Text001: Label ‘Change to Sales Order or Credit Memo Payment Method Code’;
Text002: Label 'The Count: ';
As well, In the above codeunit, I also went to Go to definition for “Sales Header”
Opened: table 36 “Sales Header”, set breakpoint on InitInsert, with no effect.
trigger OnInsert()
var
O365SalesInvoiceMgmt: Codeunit “O365 Sales Invoice Mgmt”;
StandardCodesMgt: Codeunit “Standard Codes Mgt.”;
begin
InitInsert;
InsertMode := true;
SetSellToCustomerFromFilter;
if GetFilterContNo <> ‘’ then
Validate(“Sell-to Contact No.”, GetFilterContNo);
Validate(“Payment Instructions Id”, O365SalesInvoiceMgmt.GetDefaultPaymentInstructionsId);
if “Salesperson Code” = ‘’ then
SetDefaultSalesperson;
if “Sell-to Customer No.” <> ‘’ then
StandardCodesMgt.CheckCreateSalesRecurringLines(Rec);
// Remove view filters so that the cards does not show filtered view notification
SetView(’’);
end;
settings.json
“workbench.iconTheme”: “vscode-icons”,
“telemetry.enableTelemetry”: false,
“telemetry.enableCrashReporter”: false,
“editor.renderControlCharacters”: false,
“files.autoSave”: “afterDelay”,
“editor.wordWrap”: “on”,
“workbench.colorTheme”: “Default Light+”,
“editor.selectionHighlight”: false,
“editor.occurrencesHighlight”: false,
“window.zoomLevel”: 0,
“spellright.documentTypes”: [
“markdown”,
“latex”,
“plaintext”
“spellright.ignoreFiles”: [
/.gitignore",
/.spellignore”
“spellright.language”: [
“spellright.languageContext”: {
“cSpell.userWords”: [
“Mgmt”,
“Packt”,
“Walkthrough”
“workbench.sideBar.location”: “left”,
“todo-tree.tree.showScanModeButton”: false,
“dashboard.projectData”: null,
“zenMode.centerLayout”: false,
“zenMode.fullScreen”: false,
“bdev-al-xml-doc.checkProcedureDocumentation”: true,
“al.enableCodeActions”: true,
“al.codeAnalyzers”: [
“${AppSourceCop}”,"${CodeCop}"
“editor.fontSize”: 12,
“editor.lineHeight”: 14,
“debug.allowBreakpointsEverywhere”: true,
“al.editorServicesLogLevel”: “Verbose”
debugger screenshot, after the subscription is called
Thanks for any feedback!
Are you sure you are triggering the code from the right web session? Sometimes I forget to use the newly opened window.
Thanks so much Daniel! I had previously gone to the newly opened window, as well as clearing .alchache in VS Code and the browser cache. This time, I also cleared the Vs Code credentials cache and then canceled the session in Dynamics 365 Business Central admin center. I then signed in with new credentials, the app launched and the debugger worked as expected. Not sure it should require all of that, so will see what the crucial parts are - but again, thanks for your feedback → it got me to the right place. [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Since then, non of the above steps taken seem necessary, and the debugger works after F5 and then calling the subscription. Assuming something in the steps worked, or all of them in combination - the web session likely being the being the key element. Thanks again Daniel!
