Help Index
Hello, Please guide as how to write help topics for customised fields or functions and link it respectively?? Is there any tool for the same?? Regards Satyajit.
Did anyone ever find a solution to this problem? I have two issues. One being the one described in the question above. The second is that I am trying to add a company note to the Inventory Valuation Report. My “write company note” prompt is not avaialble for this report…or any inventory report. I am able to add company notes in all other areas of the system. We are running Navision 3.7.
Since this is a beginers topic, I will create a thread there.
I don’t understand how I link to the thread you are talking about. I have continued to check for any responses and have not gotten any. I can understand a beginners forum, but should we expect beginners to be able to answer other beginner’s questions? At least from my experience here, it hasn’t helped. I am still looking for a solution to the problem of the Company Notes prompt not showing up in some area of Help.
Lori, before posting these kind of comments, I politely suggest that you either try searching or keep yourself informed on recent posts and topics: 1) beginers forum: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=15443 2) help topics: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=15545 This forum here relies on persons that voluntary spend time and effort to help people, so please write your comments accordingly… Saludos Nils
Thank you for the links. My specific problem is that the Write Company Note prompt is not available in some areas of Help. (i.e., Contents, Inventory, Tables/Reports/Batch Jobs, Reports, Inventory Valuation). Help does exist for this report as it is a standard Navision report, not a custom report. The Write Company Notes prompt is available in most areas. I had previously searched and found the links you provided in this last post, but did not find the solution. It is entirely possible that I missed it given the amount of information. If I offended you, I apologize.
Lori. you are quite correct, and I address that in the post that ils provided. Basically if there is no base help then you can not create company notes, which is very annoying I agree.
The Inventory Valuation report does have base help, however, everything automagically started working after weeks of not working. We don’t reset out servers but once a month or so, maybe that is what kick-started it. It was probably an issue with security not authenicating between the servers.
