Welcome to the user group. The best way to use the user group is be specific. Search for your specific questions, and if you don’t the answer then you’re welcome to ask the question, but as Ashok writes, please do this in the forums. So for NAV, if the question is related to the actual use of the application (incl. application setup) then use the “NAV end-user forum”. If related to development, then it’s the “NAV Developers forum”. Anything related to more technical issues, like installation, sql, database setup should be posted to the "“NAV technical forum”.
