Hello to All,
I have to create a form in which when i select the PO in upper Grid then its related ItemNumber Detail is to be shown in Lower Grid automatically. I have done the following steps but still when i select the PO in upper Grid it only shows the same PO in lower grid but not the other details and item number…The Steps which i used is as follows:-
I have created a Form named-[Header_Detail Form] in Axapta-2009.In that form i used 2 tables
Table–HeaderTable(Fields–>>ID(purchid(EDT)), lname(LastName), Name)
table–DetailTable(Fields–>>ID(purchid(EDT),itemnumber(itemid from purchline table)), and some other fields)
Then give a normal relation in Detail Table(DetailTable.ID == HeaderTable.ID)
Then Created a Form with three groups and use these tables as 2 Data Source
Group1) Header
Group2) ControlSplit
Group3) Detail
In DataSource 2(i.e. Detail_Table)–> joinsource = Header_Table & Link type is "Active"
Then In Design–>Group1–>grid property–>datasource = Header_Table
Group3–>grid property–>datasource = Detail_Table.
The Image is Shown Below.
Please suggest me some solution
