Hang when start Axapta Server Manager
When i try to start the Axapta Server Manager, it becomes hang and not responding. Anyone can solve this issue? I can’t use the AOS because of Axapta Server Manager hasn’t start. Could anyone help me? Thanks!
Provide more information. I’m using Windows 2k3 and Axapta 3.0 SP4, SQL 2000 SP3a Thanks!
I think this issue explain what you need: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=15745 Regards.
Thanks for your advice. But i’m not facing the problem of setting of AOS. Now i found that when i try to start the Axapta Server Manager, the Axapta Server Manager is hanged, and not responding. I can’t start the AOS as well. Do anyone face it before?
Hi, Provided you got all settings correctly there shouldn’t be any problems. I would try the following - 1. Are you able to ping your App server, SQL Server etc. 2. Please make sure that the settings are configured correctly including application path, client path, database path, user ID, password etc. 3. Instead of the server name, try swapping with IP address. 4. Please make sure that AOS, application and client are of same version Also do you see any error message in the Event Viewer? If possible coud you post the same here please. Regards, Harish Mohanbabu
Thanks for your help. My AOS, appl and SQL are in the same machine. And i get the follow message form teh event viewer: Hanging application AxCtrl.exe, version 3.0.1951.4060, hang module hungapp, version 0.0.0.0, hang address 0x00000000. And i check the version of the AOS and Application are the same. Would you have any idea? Thanks!
