I need to set GST values in row wise, PO having multiple lines, i used following code to print GST values
while i had multiple lines its not working showing wrong info
any help pls…
static void GSTForPOLineWise(Args _args)
vendPurchOrderJour vendPurchOrderJour;
PurchLineAllVersions ObjPurchLineAllVersions;
ITaxDocument taxDocument;
ITaxDocumentComponentLineEnumerator componentLineEnumerator;
ITaxDocumentComponentLine componentLineObject;
ITaxDocumentMeasureEnumerator measureEnumerator;
ITaxDocumentLine line;
ITaxDocumentLineEnumerator lineEnumerator;
TaxAmount taxAmount,taxValue;
TaxComponent_IN taxComponent;
vendPurchOrderJour = vendPurchOrderJour::findRecId(VendPurchOrderJour::findByPurchId("PurchaseOrderId").RecId);
taxDocument = TaxBusinessService::getTaxDocumentBySource(vendPurchOrderJour.TableId, vendPurchOrderJour.RecId);
//Tax Document not null,GST Apply start
if(taxDocument != null)
componentLineEnumerator = taxDocument.componentLines();
lineEnumerator = taxDocument.lines();
//Tax Document not null,GST Apply start-1
if (taxDocument)
//lineEnumerator for Current line taxDocument start
while(lineEnumerator.moveNext())
//Getting Current line RecId for GST start
line = lineEnumerator.current();
line.setTaxDocument(taxDocument);
if(line.originSourceRecId() != 0 && line.getInvoiceTax().value() != 0)
//componentLineEnumerator for Getting GST Rate,Amount start
while(componentLineEnumerator.moveNext())
componentLineObject = componentLineEnumerator.current();
taxComponent = componentLineObject.metaData().taxComponent();
//GST Calculation start
if(taxComponent == "CGST")
//info(strFmt("%1",VendPackingSlipTrans::findInventTransId_RU(PurchLine::findRecId(line.originSourceRecId()).InventTransId).LineNum));
taxValue = componentLineObject.getMeasure("Rate").value().value() * 100;
taxAmount = componentLineObject.getMeasure("Tax Amount").value().value();
info(strFmt("Component %1 ,Rate %2, Amount%3, RecId %4, ItemId %5",taxComponent,taxValue,taxAmount,VendPackingSlipTrans::findInventTransId_RU(PurchLine::findRecId(line.originSourceRecId()).InventTransId).RecId,VendPackingSlipTrans::findInventTransId_RU(PurchLine::findRecId(line.originSourceRecId()).InventTransId).ItemId));
if(taxComponent == "SGST")
break;
if(taxComponent == "IGST")
break;
//GST Calculation end
//componentLineEnumerator for Getting GST Rate,Amount end
//Getting Current line RecId for GST end
//lineEnumerator for Current line taxDocument end
//Tax Document not null,GST Apply end-1
