Getting The Navision Server Name As a String -HOW?
How can I get the Navision Server Name ? I’ve tried using a Navision virtual table called “Navision Server” but with no success :frowning: The following code : NavisionServer.RESET; IF NavisionServer.FIND(’-’) THEN; Would give me [Client Only] for the field “Server Name” Has anyone got a work around or the trick for getting the Navision Server Name ??? (I use a WorldWide 2.60) ###### tarek_demiati@ureach.comEdited by - Tarek Demiati on 2002 Mar 18 13:23:46
Hmm, the virtual table 2000000051 is not the current database, but shows you the published Navision databases, i guess from the Active Directory. Im not sure you can find the servername :frowning: /Soren
One can use the C/AL command CONTEXTURL to get the name of the navision server
