Hi Users,
Help Me to solve this Error
I am accessing Nav2009R2 Database from another server and i want to run a report in RTC from that database. Actually am also able to access that RTC. By Using Server/ServiceName or Server:PortNumber/ServiceName
but my Problem is i am unable to run the report from Run Command. I am getting following Error
"There is no program associated to perform the requested action. Please install a program or, if one is already installed, create an association in the Default Programs control panel. "
I am Running Report From Run Using This Command: DynamicsNAV7:////runreport?report=50001
DynamicsNAV7 is a server instance Name.
My system is Installed Both NAV 2009R2 and NAV 2013
Help me to out of this problem
Mahesh U
