Thanks to all in Advance…
I am getting Error - " Import File is not found " when i am trying to import .csv file through using inbound port for Automatic Bank reconciliation.
I done all setup like AOT-Resource- BAI2CSV-to-BAI2XML.xslt , BAI2XML-to-Reconciliation.xslt AND MT940TXT-to-MT940XML.xslt , MT940XML-to-Reconciliation.xslt and import
in inbound port i set up in Adaptor - file system adaptor and Active service Operation and click Active.its Activated also.
but still it not not import .csv file. should i do someting change in codding part
its very urgent can anyone give the solution.
Thank You once again
