Hi Community,
I am getting duplicate records while running a SSRS report
I used the following code :
SrsReportParameterAttribute(classStr(MC_StageSalesErrorContract)),
SRSReportQueryAttribute(queryStr(MC_StageSalesErrorQuery))
class MC_StageSalesErrorDp extends SRSReportDataProviderBase
MC_StageSalesErrorContract contract;
FromDate _fromDate;
ToDate _toDate;
Query query;
QueryBuildDataSource qbdsStageSalesTable, qbdsStageSalesLine;
QueryBuildDataSource qbdsDMFExecution, qbdsDMFDefinitionGroup, qbdsDMFStagingValidationLog, qbdsDMFDefinitionGroupExecution;
QueryBuildRange queryBuildRange;
QueryRun queryRun;
MC_StageSalesTableStagingTmp stageSalesTableTmp;
MC_HIMSIntegrationSalesStageTableStaging stageSalesTable;
MC_HIMSIntegrationSalesStageLineStaging stageSalesLine;
DMFExecution dMFExecution;
DMFDefinitionGroup dMFDefinitionGroup;
DMFStagingValidationLog dMFStagingValidationLog;
DMFDefinitionGroupExecution dMFDefinitionGroupExecution;
[SrsReportDataSetAttribute(tableStr(MC_StageSalesTableStagingTmp))]
public MC_StageSalesTableStagingTmp getData()
select stageSalesTableTmp;
return stageSalesTableTmp;
public void processReport()
super();
utcdatetime fromDateTime;
utcdatetime toDateTime;
query = this.parmQuery();
contract = this.parmDataContract() as MC_StageSalesErrorContract;
_fromDate = contract.parmFromDate();
_toDate = contract.parmToDate();
if(_fromDate && _toDate)
fromDateTime = DateTimeUtil::newDateTime(_fromDate, 0*0*0, DateTimeUtil::getUserPreferredTimeZone());
toDateTime = DateTimeUtil::newDateTime(_toDate, 24*60*60, DateTimeUtil::getUserPreferredTimeZone());
qbdsStageSalesTable = query.dataSourceTable(tableNum(MC_HIMSIntegrationSalesStageTableStaging));
qbdsStageSalesTable.addRange(fieldNum(MC_HIMSIntegrationSalesStageTableStaging, TransferStatus)).value(SysQuery::valueNot(DMFTransferStatus::Completed));
qbdsDMFExecution = qbdsStageSalesTable.addDataSource(tableNum(DMFExecution));
qbdsDMFExecution.addLink(fieldNum(MC_HIMSIntegrationSalesStageTableStaging, ExecutionId), fieldNum(DMFExecution, ExecutionId));
qbdsDMFExecution.addRange(fieldNum(DMFExecution, CreatedDateTime)).value(queryRange(fromDateTime, toDateTime));
qbdsDMFDefinitionGroupExecution = qbdsStageSalesTable.addDataSource(tableNum(DMFDefinitionGroupExecution));
qbdsDMFDefinitionGroupExecution.addLink(fieldNum(DMFExecution, ExecutionId), fieldNum(DMFDefinitionGroupExecution, ExecutionId));
qbdsDMFDefinitionGroup = qbdsStageSalesTable.addDataSource(tableNum(DMFDefinitionGroup));
qbdsDMFDefinitionGroup.addLink(fieldNum(DMFDefinitionGroupExecution, DefinitionGroup), fieldNum(DMFDefinitionGroup, DefinitionGroupName));
qbdsDMFDefinitionGroup.addRange(fieldNum(DMFDefinitionGroup, ProjectCategory)).value(queryValue(DMFProjectCategory::Integration));
qbdsDMFDefinitionGroup.addRange(fieldNum(DMFDefinitionGroup, OperationType)).value(queryValue(DMFOperationType::Import));
qbdsDMFStagingValidationLog = qbdsStageSalesTable.addDataSource(tableNum(DMFStagingValidationLog));
qbdsDMFStagingValidationLog.addLink(fieldNum(MC_HIMSIntegrationSalesStageTableStaging, ExecutionId), fieldNum(DMFStagingValidationLog, ExecutionId));
queryRun = new QueryRun(query);
ttsbegin;
while(queryRun.next())
stageSalesTable = queryRun.get(tableNum(MC_HIMSIntegrationSalesStageTableStaging));
dMFExecution = queryRun.get(tableNum(DMFExecution));
dMFDefinitionGroup = queryRun.get(tableNum(DMFDefinitionGroup));
dMFStagingValidationLog = queryRun.get(tableNum(DMFStagingValidationLog));
stageSalesTableTmp.clear();
stageSalesTableTmp.DefinitionGroup = dMFExecution.DefinitionGroup;
stageSalesTableTmp.Description = dMFExecution.Description;
stageSalesTableTmp.Company = dMFExecution.Company;
stageSalesTableTmp.ExecutionId = stageSalesTable.ExecutionId;
stageSalesTableTmp.TransferStatus = stageSalesTable.TransferStatus;
stageSalesTableTmp.ErrorMessage = dMFStagingValidationLog.ErrorMessage;
stageSalesTableTmp.ExecutionTime = dMFExecution.CreatedDateTime;
stageSalesTableTmp.OperationType = dMFDefinitionGroup.OperationType;
stageSalesTableTmp.ProjectCategory = dMFDefinitionGroup.ProjectCategory;
stageSalesTableTmp.DocumentType = stageSalesTable.DocumentType;
stageSalesTableTmp.HIMSTransType = stageSalesTable.HIMSTransType;
stageSalesTableTmp.AccountNum = stageSalesTable.AccountNum;
stageSalesTableTmp.PartyCategory = stageSalesTable.PartyCategory;
stageSalesTableTmp.IPNumber = stageSalesTable.IPNumber;
stageSalesTableTmp.InvoiceId = stageSalesTable.InvoiceId;
stageSalesTableTmp.InvoiceDate = stageSalesTable.InvoiceDate;
stageSalesTableTmp.HIMSCostCenter = stageSalesTable.HIMSCostCenter;
stageSalesTableTmp.HIMSCostCenterName = stageSalesTable.HIMSCostCenterName;
stageSalesTableTmp.HIMSDepartment = stageSalesTable.HIMSDepartment;
stageSalesTableTmp.HIMSDepartmentName = stageSalesTable.HIMSDepartmentName;
stageSalesTableTmp.NetAmount = stageSalesTable.NetAmount;
stageSalesTableTmp.GrossAmount = stageSalesTable.GrossAmount;
stageSalesTableTmp.SponsorCategory = stageSalesTable.SponsorCategory;
stageSalesTableTmp.SponsorDueAmount = stageSalesTable.SponsorDueAmount;
stageSalesTableTmp.SponsorDiscount = stageSalesTable.SponsorDiscount;
stageSalesTableTmp.PartyName = stageSalesTable.PartyName;
stageSalesTableTmp.FirstName = stageSalesTable.FirstName;
stageSalesTableTmp.MiddleName = stageSalesTable.MiddleName;
stageSalesTableTmp.LastName = stageSalesTable.LastName;
stageSalesTableTmp.PartyType = stageSalesTable.PartyType;
stageSalesTableTmp.CountryCode = stageSalesTable.CountryCode;
stageSalesTableTmp.insert();
ttscommit;
My requirement is that to get the list of records of errors and its message, and the records which haven’t posted (I.e. - Other that Completed) . I need these records while we do Import in Integration.
I need to know the reason for, why I am getting duplicate records. Are the relations between the Tables (which I used in above Code) are Valid ? And also is there any possibilities to code in DP Class ( Other that using those While Statements using JOIN).
-Thanks in Advance
