Hello Friends
please advice me for a tool which i can use it to get Data from Nav 3.7 to MS Access
Best Regards
Hello Friends
Best Regards
Hi Rami and welcome to forum,
Depends on what database you use - Native or MS SQL.
For Native there is NODBC driver (search here in Downloads, if you do not have 3.7 install CD), for SQL there are numerous options.
Hello!
You could use the ADO automations in NAV.
An example:
Here is the automations you’ll use:
ADOConnection Automation ‘Microsoft ActiveX Data Objects 2.6 Library’.Connection
ADORecordSet Automation ‘Microsoft ActiveX Data Objects 2.6 Library’.Recordset
CREATE(ADOConnection);
CREATE(ADORecordSet);
filepath := ‘c:\mydatabase.mdb’;
connectionString := ‘Provider=Microsoft.Jet.OLEDB.4.0;Data Source=’+filepath+’;’;
ADORecordSet.CursorType := 3;
ADOConnection.ConnectionString := connectionString;
ADOConnection.ConnectionTimeout := 10000;
ADOConnection.CommandTimeout := 10000;
ADOConnection.Open;
sqlQuery := ‘INSERT INTO myTable (field1,field2) values (myvalues1,myvalues2)’; //string values would be surraounded with two single-apostrophe (eg. ‘‘value’’)
ADOConnection.Execute(sqlQuery, result);
message(’%1 records affected’, result);
ADOConnection.Close();
HI
1.Install NODBC [Available in Navision Istallation DVD]
2.Create a data source for navision databse]
The following steps show how to create a DSN.
3.Consume the data source for MS access
Go to Ms Access Help(F!) and search as Import or link
Data that is entered through ODBC is not validated. It is important to
ensure the data entered meets the criteria of the data type for that
field.
Jerome Marshal.J
