After scheduling (Job Scheduling) a production order, system is updating scheduling start & end date correctly for ex. start date 21 Aug & end date 22 Aug.
Production order started on 21 Aug & a related route card created successfully on 21 Aug.
However, after trying to post the route card on date after scheduling end (22 Aug) date i.e. 23 Aug, system is overwriting the scheduling start & end date on the production order & can see the new scheduling start & end date as 23 Aug.
At the same time, while posting the route card, system is throwing a warning message as " Attempts are made to schedule production before today’s date or before materials are available.
Scheduling direction is thus automatically changed to forward from today’s date. ".
Is there any set up missing which causes this issue ?
AX version - AX 2012 R3
I dont believe there is anything standard that would do this in AX2012, I presume you have customisations in place? You also dont actually state how you are creating or posting the route card, but no I do not see why it would retrospectively update the field as standard on completion.
You would need a test Contoso system that is vanilla to test it in.
