Getting a Value from reference Group
hi i am using dyanmics ax 2012.
I want to keep a validation on a field by fetching its value but the control on the form is Reference group control.
How do i fetch value from it?
I tried using ValueStr() and value but not getting the exact value in the field.
#Define.controlName(TestControl)
FormReferenceGroupControl testReferenceControl = Grid.addControl(FormControlType::ReferenceGroup, #controlName);
testReferenceControl.dataSource(tableStr(testDataSourceTable));
testReferenceControl.referenceField(fieldNum(testDataSourceTable, testField));
testReferenceControl.visible(false);
is it a macro?
Where do i have to write this code?
FormReferenceGroupControl.value() returns the reference. If you’re interested in a replacement value, find a record by the reference and get other fields from the record.
on this form InventNonConformanceTableCreate i am having the field worker responsible.(Which is a reference group)
on click of ok
i want to check that the value in that field is not null.
even if i have selected nothing i am not getting null value instead i am getting some number
i tried
a =reportedBy.value();
info(strFmt("%1",a));
if(a ==0)
warning(‘The field “reportedby” cannot be blank’);
or by valuestr() but not able to get the reference or value.
what should i do?
i am using ax 2012 r2
You’re looking at a wrong field - Worker responsible is CreateInformation_TestResponsibleWorker control. Because the control is bound to a field, access it through the data source, i.e. inventNonConformanceTable.TestResponsibleWorker.
By the way, Reported by is initialized automatically in the init() method, therefore it has a value even if you never choose it manually.
Thanks Martin You saved the day…
