With Microsoft Common Dialog Control it is possible to select a file (not a directory) on disk from within Navision. Anybody knows a method to browse a disk and select a directory instead of a file the same way? Regards, Wilfried
This is so often discussed, that you should use the search function of this board
Hi Try this thread http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=7734
If I understand you correctly, you are trying to display a “Browse for Folder” dialog. Check out my download on www.mibuso.com.
