How to get the value of a cell in the selected row in a grid?
Ex: Say i have some customer details in the grid and say i select the 3rd row.I want to retrieve customer account number of the selected row.How can this be done?I want to do this at the form level and not on the datasource level.
I need the account number on the Form level on clicked method of a button.I tried the datasource method mentioned by sunil but it doesnt quite suite the requirement as active event fires everytime i select a new row.
i want to select a row->click a button on the button group ->it should give me the customerAccount number.
If it is the button control,to capture selected record ,
Add check box over there,then mark the checkbox when you click the button override the clicked method and write the select query basing on the marked check box…you get the table buffer…so can get the accountnum
If using the menuitembutton,then need to added the menuitemtype(display),menuitemname(Ex: CustomerAccountForm),datasource(i.e the custtable) for the menuitembutton properties…
In the CustomerAccountForm – init method…you will get the record of the cusotmer so it can be displayed…
