Hi all , i want to modified form Chart Of Accounts (form 16)
so there will be a field beside net change that show Last Month Net change
for example I give date filter 02/15/09…02/28/09
so the the net change date filter should be 02/15/09…02/28/09
and new field (lAst month net change) should be 01/15/09…01/28/09
StartDate := DMY2DATE(01, month, CurrYear); // StartDate will be the date of the first day of the month
EndDate := DMY2DATE(01, month+1, CurrYear)-1; // EndDate will be the last day of the month
// month+1 => increments the month (for the next month)
// DMY2DATE(01, month+1, CurrYear)-1 => the -1 decrements a day to the date calculated by the DMY2DATE formula.
Now enter a month in the month text box (1…12).
Press the command button
If you enter month 2… you will see the StartDate and EndDate being filled with 01-02-10 and 28-02-10.
I use this code to place a date filter in a table: the user inputs the month and this code allows me to create the range of dates correspondent to that month.
Just play with it and see if you can change it to match your needs.
