Generate more than one file
In Objet Form 13382 a procedure generate one file with some financial Data.
XMLPort 13301 creates that file.
I Pretend create a new XMLPort, that generates all financial doc’s by vendor nº. But for each vendor Nº I pretend generate one file in my system.
Run a XML Port that for each vendor Nº, creates a diferent file . txt?
How can I do That?
Following link might help you…
http://msdn.microsoft.com/en-us/library/hh166529(v=nav.70).aspx
Hi loop running the xml port through code. on your button
if vendorrec.findset then begin
repeat
XMLPORT.EXPORT(xmlportnumber,path,vendorrec);
until vendor.next=o;
end;
Hello Anil
I Inserted this code in CU 412 on Open File
IF Vendor.FINDSET THEN BEGIN
REPEAT
VendXmlFile.CREATE(‘C:\SAFT\Vendor.xml’);
VendXmlFile.CREATEOUTSTREAM(XmlStream);
XMLPORT.EXPORT(50004, XmlStream);
VendXmlFile.CLOSE;
XMLPORT.EXPORT(50004,‘C:\Vend.xml’,Vendor);
//MESSAGE(‘Passou aqui1’);
UNTIL Vendor.NEXT=0;
END;
But I a geting a error message when I Comppile my CU Objet
XML Port 0 Does not Exists.
Hi Luana,
Not quite sure what you’re trying to do here. Don’t mess with CU 412 for this. Create a new codeunit for this call.
And try this instead:
REPEAT
FileName := 'VEND'+Vendor."No."; // To have a file per vendor
VendXmlFile.CREATE('Filename);
VendXmlFile.CREATEOUTSTREAM(MyXmlStream);
MyXMLPORT.SETDESTINATION(MyXMLStream);
MyXMLPORT.EXPORT;
VendXmlFile.CLOSE;
Hy Erik
The question is.
I use the Form object 13382. This forms calls Code Unit 412. This form generate one only file with all customer data.
I Pretend change Object 13382 and probably CU 412, to generate more than one file with the same customer data , but for Vendor Table.
But I need to generate one xml file by Vendor Nº.
Can you help me with this?
I am trying several days with no Sucsess :frowning:
Hy Erik
Any Idear?
I can try and take a session if that is ok for you… the code that i or erick posted should work… did u try that…?
Anil.
I Tryed. But I don’t now if I done corretly your sugestion:
I put Erick code on OnPush() Button of Form object 13382. I Comment all standard code.
Like this:
- OnPush()
IF ISSERVICETIER THEN
FileName := RBMgt.EnvironFileName(’’,‘xml’);
//IF FileName = ‘’ THEN
// ERROR(Text1110001);
REPEAT
FileName := ‘C:\VEND’+ Vendor.“No.”; // To have a file per vendor
VendXmlFile.CREATE(FileName);
VendXmlFile.CREATEOUTSTREAM(MyXMLStream);
MyXMLPORT.EXPORT;
VendXmlFile.CLOSE;
{TempFileName := FileName + ‘.tmp’;
IF LastDate < StartingDate THEN
ERROR(Text13301,StartingDate);
OutputFile.TEXTMODE(TRUE);
OutputFile.WRITEMODE(TRUE);
IF NOT ISSERVICETIER THEN OutputFile.QUERYREPLACE(TRUE);
OutputFile.CREATE(TempFileName);
OutputFile.CREATEOUTSTREAM(OutputStream);
//NAVPTL001.001,sn
IF ShortVersion THEN BEGIN
ShortSAFTPT.SetData(LastDate,StartingDate);
ShortSAFTPT.SETDESTINATION(OutputStream);
ShortSAFTPT.EXPORT;
END ELSE BEGIN
//NAVPTL001.001,en
SAFTPT.EXPORT;
END;//NAVPTL001.001,n
OutputFile.CLOSE; }
IF ISSERVICETIER THEN BEGIN
ToFile := Text1110005;
SAFTPT.ModifyNameSpace(TempFileName);
DOWNLOAD(TempFileName,Text000,’’,Text001,ToFile);
MESSAGE(Text1110000,ToFile);
END ELSE
MESSAGE(Text1110000,FileName);
CurrForm.CLOSE;
CheckANDModifyFile(TempFileName,FileName);
I Have now one file by vendor number. Bir the xmf has a bad stucture.
I will try a litle more, sooner i make a contact.~
Hy
At this moment I have one file for each vendor, but when I execute my Form I get one error message:
I Must give OK to continue.
How can I avoid this message
Hy
Just close your xml file after u create the file for each record.
just use…
xmlfile.close;
this should help you.
Anil
I have done it, as you can see im my code above
REPEAT
MyXMLPORT.EXPORT;
VendXmlFile.CLOSE;
I have my Form Buton MenuItem
Like this the message for close file apears.
the xmlfile.Close is correctly inserted?
- OnPush()
REPEAT
MyXMLPORT.EXPORT;
VendXmlFile.CLOSE;
//NAVPTL001.001,sn
ShortSAFTPT.EXPORT;
END ELSE BEGIN
//NAVPTL001.001,en
SAFTPT.EXPORT;
OutputFile.CLOSE;
// MESSAGE(Text1110000,ToFile);
END ELSE
// MESSAGE(Text1110000,FileName);
CurrForm.CLOSE;
Anil
Any idear?
Anil
Where do I have to put VendXmlFile.CLOSE?
ITryed this and the same error message appear
REPEAT
MyXMLPORT.EXPORT;
VendXmlFile.CLOSE;
//NAVPTL001.001,sn
ShortSAFTPT.EXPORT;
END ELSE BEGIN
//NAVPTL001.001,en
SAFTPT.EXPORT;
OutputFile.CLOSE;
// VendXmlFile.CLOSE;
END ELSE
CurrForm.CLOSE;
//VendXmlFile.CLOSE;
