And the question kinda was… How was the lines created. We do know its a journal batch
-is it standard Code?
Can you post a single line?
What line is the exact problem (use the debugger to find it)?
This should never be able to happen on standard NAV code, and the solution is surely NOT to delete any created GL or VAT Entries, that is a crazy suggestion!!!
If the code is 100 standard then there is one “old” problem and that is if you post many lines with documents no and different posting dates. For Example you can get a posting error i some cases if
Line No / Posting Date / Document No.
1 / 01-01-01/ 1
2 / 03-03-03/ 2
3 / 02-02-02 / 3
Problem is increasing Document Nos, with declining Posting Dates.
The Solution is to try to filter (ALT+F3) on one of the Posting Dates and post all lines.
REMEMBER - The general rule is: the more detailed question on how to reproduce the error, with example of “demo-Data” gives you the best answer to your problem. Right know its a lot of “no-brain” mails back and forward gaining enough information to give the right answer.
Where is the 1 line for the journal batch come from? (if it is standard system without code injection and you can’t post 10 lines the issue with posting data).
What line is the exact problem (use the debugger to find it)? It happens on the fifth line when posting all lines at once and then when you decide to post one line at a time
And the question kinda was… How was the lines created. We do know its a journal batch : The lines were entered manually and the posting dates are the same.
This is what I found out also:
G/L Entry Table
12375 - the last entry number
VAT Entry Table
4988 - the last entry number
G/L Entry - VAT Entry link Table
12375 4988 - link between the the last G/L Entry Number and the last VAT Entry Number
12376 4989
12377 4990
12378 4991
12379 4992
12380 4993
12381 4994
12382 4995
12383 4996
12384 4997
That did not really answer all of Palle’s questions!!!
Is it in a 100% standard unmodified NAV database? With no changes (whatsoever)?
Are you able to post a single line? Also when did this error start and does it happen in other journals also? Mean what is different when it works and when it doesn’t work?
And when you ran it with the debugger, as suggested by Palle, then where in the code does it happen?
It is really difficult to help you, when you only add part of the information in each post and we have to drag every answer out. You have been a member here since 2012, so you should know how to ask a question… [emoticon:ca08b2c27c2f40e993e89508acf29e0b]
It’s a standard nav 2013 W1 database with no modification. I am not able to post a single line.
This is the first time and it happened on Monday 8th October, 2018 and it does happen in general journal too.
When I debug, in the codeunit 12 under the function “InsertVAT”, when the “InsertLink” function on table 253 (G/L Entry - VAT Entry link) is called the message pops up- It is about to insert the link between the g/l entry and vat entry into the “G/L Entry - VAT Entry link” Table.
