Function to get field's last value
Dear:-
Please do help ,how can i get the value of one feilds last value ,give me the c/side query/functon for that.
Please provide more details about your requirement. In case you want to know the value last stored in a field (or to check if the value in field is changed), then
xRec.Field is what you are looking for.
If you want to check or find the last values in integer or decimal fields you can define them as key and use the FINDLAST function.
Take the field in a variable. It will be helpful otherwise xRec.Field is the best one.
If you want to find last value then FINDLAST/ find(’+’) is best way.
if Customer.findlast then repeat
until Customer.Next=0;
or You can simply take a variable,because variable always hold last value of the field.so i think it is more simpler.
If you use FINDLAST there is no need to call NEXT like that; there shouldn’t be any next. But using NEXT(-1) could be relevant… [;)]
Thank u all
