I have function for uploading a file to ftp and I woud like to know the equivalent function for downloading and renaming the file. I have no experience with c# I only use this functions to post them to azure function and then consume them in BC. I would be thankful is anyone could show or guide me to have the equivalent function for the download and the one for rename; Below is the upload function :
[FunctionName("FtpStor")]
public static async Task<IActionResult> Run(
[HttpTrigger(AuthorizationLevel.Anonymous, "post", Route = null)] HttpRequest req,
ILogger log)
log.LogInformation("C# HTTP trigger function processed a request.");
string requestBody = await new StreamReader(req.Body).ReadToEndAsync();
dynamic data = JsonConvert.DeserializeObject(requestBody);
string fileUri = data.fileUri;
string username = data.username;
string password = data.password;
string filename = data.filename;
string ContentFileToBase64String = data.ContentFileToBase64String;
var bytes = Convert.FromBase64String(ContentFileToBase64String);
Stream fileStream = new MemoryStream(bytes);
//Upload to FTP
FtpWebRequest ftpWebRequest = (FtpWebRequest)WebRequest.Create(fileUri);
ftpWebRequest.Method = WebRequestMethods.Ftp.UploadFile;
ftpWebRequest.Credentials = new NetworkCredential(username,password);
ftpWebRequest.UsePassive = true;
using (Stream requestStream = ftpWebRequest.GetRequestStream())
await fileStream.CopyToAsync(requestStream);
fileStream.Dispose();
using (FtpWebResponse response = (FtpWebResponse)await ftpWebRequest.GetResponseAsync())
string result = response.StatusDescription;
return response.StatusCode == FtpStatusCode.ClosingData
? (ActionResult)new OkObjectResult(result)
: new BadRequestObjectResult(result);
And this the function that i'm using to call the ftp download :
RequestContent.Clear();
Client.Clear();
fileuri := 'ftp://*****:21/TEST/file.txt';
uri := 'https://*****.azurewebsites.net/api/FtpDownload?';
RequestBody := '{';
RequestBody += 'fileUri:"' + fileUri + '",';
RequestBody += 'username:"******",';
RequestBody += 'password:"*****",';
RequestBody += '}';
RequestContent.WriteFrom(RequestBody);
RequestContent.GetHeaders(RequestHeaders);
RequestHeaders.Clear();
RequestHeaders.Add('Content-Type', 'application/json');
RequestMessage.Content := RequestContent;
Client.Post(uri, RequestContent, ResponseMessage);
ResponseMessage.Content().ReadAs(OutputString);
tempblob.CreateInStream(FromInStream);
FromInStream.Read(OutputString);
Fromfile := 'file.txt';
DownloadFromStream(FromInStream, '', '', '', Fromfile);
