Form「users」's 「Import Users」 function with error "Authorization Required"
I am encountering an issue when using the “Import Users” function in the D365 Users screen. Every time I try to use this function, I receive an error message saying “Authorization Required.”
If this is a recently created DevBox, MS does not link those to your tenant since Nov 2023. There is an article out there regarding this.
Thank you! I will try setting up the new environment based on the MSDN “Secure one-box development environments - Finance & Operations | Dynamics 365 | Microsoft Learn
You can do create new user instead. Provide proper name, email id & network alias, if it matches with the data in azure active directory, the user will be able to login. We have done it this way & it is working as expected.
Hi, do you know if this was resolved for DEV environments?
i believe you still have to do it manually.
