hi every one,
Can any one help me sort small issue.
I want to refresh my form whenever i move different records in grid. When i move cursor to different record in grid then form should get refreshed…
Thanks in advance.
hi every one,
Thanks in advance.
Hi ,
try with
datasourcename.reread();
datasourcename.refresh();
After ur code
Hello jyothi,
Thanks for quick reply.
In which method should i use the reread and refresh statement?
Rajendra
I am Able refresh data source. But in my form i am enabling and disabling buttons whenever i move cursor to different records in grid.
Hi Rajendra,
where ever ur enabling and disabling the buttons after that u try to refresh…and after that write Datasourcename.executequery()
Hi Jyothi,
I am enabling and disabling buttons in data source active method. Form is continuously refreshes if i use refresh and reread in Active method.
Rajendra
Enabling and disabling doesn’t need a refresh or reread, don’t call them on active method only place the enable/disable logic on active method.
Hi kranthi,
After removing refresh and reread datasource is getting refreshed but form buttons are not refreshing.
Rajendra
If i press F5 then form is getting refreshed.
