Dear Frnds
I have one requirement , i am doing the new form in that overview, General & Accrual three tab pages are three
In overview grid Accrual field (yes/no combo box type), if i select “yes” then only accrual Tab fields are Enable otherwise Disable
in data source , Accrual field i wrote a modified method like as follows below
public void modified()
super();
if (CEMPAbsence.Accrual == Accrual::Yes )
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,AccrualType)).enabled(True);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Numberofunits)).enabled(True);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Rule)).enabled(True);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Accrueperiod)).enabled(True);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,FromDate)).enabled(True);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Accrueperiodunit)).enabled(True);
else
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,AccrualType)).enabled(false);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Numberofunits)).enabled(false);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Rule)).enabled(false);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Accrueperiod)).enabled(false);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,FromDate)).enabled(false);
CEMPAbsence_ds.object(fieldNum(CEMPAbsence,Accrueperiodunit)).enabled(false);
CEMPAbsence_ds.reread();
CEMPAbsence_ds.refresh();
but one problem is there when i reopen the form
this one is not working
can u plz give the suggestion any body
