'm facing an filter problem here…i have a form with an option field phase with 5 choices…now can i use this same form and filter for different phases and call this filtered different phases in another table?(like first time i need 4 of the 5 phases option, second time 3 of the option)
P.S…i have tried sourcetableview…but i can filter only 1 field in that, when i try to do more the form doesnt display the filter info…
i have a form 1…in which 'm goning to show form2’s different fields value on the basis of phase filter. consider i have a “shortterm” that consist of only 3 phases…and tiny phase consisting of 2 phases…but both of this i should show in form 1!
in your post you mentioned firt time you will use 4 out of the 5 option values as a filter,and the second time you will use 3 out of the 5 optins values as a flter.the code whic i mentioned is to achive the above mentioned filter.
Let me tel you my unederstanding
1.You have form A and B
2.Now you are applying some filters based on the option value on form A
3.Now you want to apply the same filter on the Form B
4.Now you want to populate some values on aForm A from Form B
Am I correct
if i’m correct
1.use copy filter on the source table of Form A
2.Apply the copied filter on the Form B’s Source Table
3.Update the form B
3.get the values from form B and poulate it in form A’s source table
4.Update the form A
if my understanding is wrong,Kindly give us more details
