Form does not show any data when called from menu on Action Pane
Hi guyz ;
I have a form which does not return data when i call it from a menu item on an action pane. If i run the same
form directly it returns all the data in the table. What could be happening?
Hi
if you open form directly are you getting data.?
if…check in your menuItem → properties.
