Please tell me that how can we keep a paticular field not editable more than one time.
for example-
there is a field finance location which filled on the bases of “Dimension” field . and when i select the customer on that form than the field updated with the value that is on the customer master’s Dimension
You must run your query in such a way that even when u select the customer on that form, it (i.e, field finnace location) should get populate or update with the same value which filled on the basis of ‘dimension field’.
Basically when you dont want your field to get updated based on some other selecion of field then just debug and find out where exactly its filling that value. so by this you can prevent it by getting updated.
u are saying that… there is a field finance location which filled on the bases of “Dimension” field . and when i select the customer on that form than the field updated with the value that is on the customer master’s Dimension…
by default the value is populated from the customer master’s Dimension right…
so do onething… just go to the table where field finance location is there
and change the allow edit on create, allow edit properties to NO… for that field…
