I have a problem on a StringEdit field (which is not bind to any data source), I use it as a string input field (with a button to do some special job)
and I found that if I type anything on it then then leave it by press tab key or just click any other control, the validate method will be executed as expectation.
but if I paste a string onto it and press Tab or click any other control, it will not trigger validate method.
I know that paste() method will be called when I paste text onto it, but at this time, I can not get the text I pasted on it by this.text() → it is blank.
I was wondering how can I do the validate() while I paste text onto a StringEdit (form control)
many thanks.
