I have a form with the DetailsMaster design pattern.
In the form, the removeFilter method of the Main DataSource is called when I trigger the New Button in the form.
If I stop with a breakpoint in the removeFilet, I cannot see who triggered it.
There is no call to removeFilter in the code itself.
The filters should not be deleted.
The question now is: What can trigger the removeFiler?
Here is the callstack when I set a breakpoint in removeFilter
> |Dynamics.AX.CargoSuiteTMS.Forms.ANXTMSCustInvoiceTableNew.netmodule!Dynamics.AX.Application.Forms.ANXTMSCustInvoiceTableNew.FormDataSource.ANXTMSCustInvoiceTable.`removeFilter() Line 245|X++|
> |[Lightweight Function]||
> |Microsoft.Dynamics.AX.Xpp.Support.dll!Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.KernelToXppInstanceCallCoC(object instance, string methodName, string nestedElementName, string rootName, object[] parameters) Line 3015|C#|
> |aoskernel.dll!Microsoft.Dynamics.Ax.MSIL.cqlClassIL.InvokeInstanceCallHandlerCoC(object instance, string MethodName, string NestedElementName, string RootName, object[] parameters)|Unknown|
> |aoskernel.dll!<Module>.callILClassMethodCoC(interpret* ip, char* method, char* nestedConceptName, char* rootName, uint chdl, cqlClass* c)|Unknown|
> |[Native to Managed Transition]||
> |[Managed to Native Transition]||
> |aoskernel.dll!Microsoft.Dynamics.Ax.MSIL.cqlClassIL.Call(System.IntPtr c, string methodName, object[] parameters, System.Type[] types, object[] varargs, System.Type[] varargsTypes)|Unknown|
> |Microsoft.Dynamics.AX.Server.Core.dll!Microsoft.Dynamics.Ax.Xpp.XppObjectBase.Call(string methodName, object[] parameters, System.Type[] types, object[] varargs) Line 257|C#|
> |Dynamics.AX.ApplicationPlatform.1.netmodule!Dynamics.AX.Application.FormRun.`task(int _p1) Line 1426|X++|
> |aoskernel.dll!<Module>.callILClassMethod(interpret* ip, char* method, uint chdl, cqlClass* c)|Unknown|
> |aoskernel.dll!Microsoft.Dynamics.Client.ServerForm.Interactions.InteractionManager.ProcessPendingOperations(bool useSnapshot)|Unknown|
> |aoskernel.dll!Microsoft.Dynamics.Client.ServerForm.Interactions.InteractionManager.ProcessMessages(object stateinfo)|Unknown|
> |mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx)|Unknown|
> |mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx)|Unknown|
> |mscorlib.dll!System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()|Unknown|
> |mscorlib.dll!System.Threading.ThreadPoolWorkQueue.Dispatch()|Unknown|
Can anyone see what triggers the removeFilter?
Is it related to a setting in the form or the data source?
I have other forms with the same design pattern in the project that do not show the behavior, but I cannot find any relevant differences in the settings.
