Hello all. How can I change ‘.fob’ backup file to ‘.txt’ file. Or how can I view contents of ‘.fob’ file. Please help as I am stuck with migration. Thanks in advance.
I got an error while uploading .fob file that ‘The field is not present in Table’. I suppose that, its obvious that new fields will be created whenever customization will be there. Should I be getting such error?
Thanks and Regards,
Yash Shah.
Hello,Select object in object designer File → Export to txt. Then import object ,dont compile it to view the code, bus as Saurav Dhyani described in #2, wont give much ;).
Hy Saurav,
Thanks for the prompt reply ,as always.
Yes, those fields are in that range only. To be specific, I have created field 50013 in Purchase Line. Does it mean, before importing, I will have to be create field 50013 and then import the fob file?
Maybe I am taking it wrong. Coz as far as I remember, that is not how it used to work before.!! :?
The thing is I have fob file of all my objects, which I need to import. But unfortunately it showed error, saying ‘The field 50013 is not available in Purchase Line’. So I felt I can atleast view which field it is if I had ‘.txt’ version of the backup. So that I can manually create that field and again start my Import. I hope I am being clear.
Yash Shah.
