Flowfilter in RTC
In classic client by default all fields with type FlowFilter will be listed. we can also add some more fields in run time by pressing SHIFT+F7, here we can mention any fields other than flowfilter also.
In RTC i have to add fields other than FlowFilter fields how do i achieve it ?
Sorry, but I guess I do not get the question correctly but what you can do:
(Example “Chart of Accounts”)
When you click the dropDown just beside the name of the form (directly below the “New” button), you can Show/Hide the “Advanced Filter” = Show Results which you also can reach by using the field in the same line as the titel of the form at the very right, and also Show/Hide the “Limit Totals” which equals the former “Shift+F7” to set flow filters.
Now you can set a filter to any column you want and also to any flow filter field.
In the RTC you filter from a list, not a page. When in a list the filter controls are in the upper right side of the list, select the drop down next to the Type to filter box and select a field, if you need to filter on more fields then listed click on the button (a circle with a arrow) and the filter options will expand. You can then add/select new fields.
For shortcuts Shift +F7 is now CTR+Shift+F
2843.Classic Client.bmp (246 KB)
For Eg. purpose, I have taken Order Date, it can be any field from the table.
Thank u its working fine Thomas. Ignore previous post
Please do mark the post as being a (the) “Solution” for your question by clicking the “Verify Solution” button in answer post.
This helps us - who answered - and also all members of the post with a similar question to quickly identify the solution which solved the problem.
Dear Thomas,
I saw your explanation regarding adding fields as filters in RTC. I cant able to understand how to add Fields for the pages that has been customized. please help me in solving this problem.
Seshadri.
