I am inserting data from excel through code.it is inserted in table but it is not visible in form.I checked with Debugger FK Replacement Key failed.
Please tell me how to solve this ?
HI,
Try restarting AX or AOS service, it is quite common issue in AX. This is how AX responds always
Trish!
If that doesnt works out add replacement key and then generate full CIL. All the best
Hi Trishant,
I restarted the service and run full CIL.But i get the same error
try using replacement keys in your form…it should work out
